Need to make 4 - 20mA loop isolators
Discussion in 'The Projects Forum' started by bowlingo, Feb 17, 2012.
  1. bowlingo
    Jun 29, 2011
    162
    Hi all,
    I have a combined PH and CF transmitter of which can be found here
    http://www.omega.co.uk/ppt/pptsc.asp?ref=CDTX300
    I need to make 2 x 4 - 20mA loop isolators that I can connect to each output. The unit runs on a 24V power supply
    Someone has pointed me to some of the components
    http://docs-europe.electrocomponents.com/webdocs/0028/0900766b800289f3.pdf
    http://www.rapidonline.com/Electric...106/?sid=003c3b70-f289-488d-b4a3-bb276c21a821
    This will be the fist time I have made something like this and would like to do it on small prototype boards with chip housings etc.
    Can anyone provide me with the correct parts from farnell or RS and possibly an easy to understand diagram?
  2. bowlingo
    Jun 29, 2011
    162
    Anyone any ideas?
  3. MrChips
    Oct 2, 2009
    12,636
    3,455
    I would assume that if two readings are transmitted via a two wire interface, then this is a digital output. You will need a digital processor such as a microcomputer to interrogate the data.
  4. bowlingo
    Jun 29, 2011
    162
    This is the unit I have used on it in the past
    http://uk.rs-online.com/web/p/produ...552267573743D343636323231342677633D4E4F4E4526
    As you can see its disgustingly expensive £134.40 including VAT
    I am sure these can be made easily using basic components and a bit of soldering..trouble is what components from RS or Farnells, chip housing etc and a wiring diagram...I would like to use the existing 24V DC supply
  5. MrChips
    Oct 2, 2009
    12,636
    3,455
    I can never figure why people say it must be easy to do and they come running to us for help.
  6. bowlingo
    Jun 29, 2011
    162
    That is a very good point..can anyone who knows how to do this help me please as quite rightly as mrchips has pointed out its not easy to do hence the reason I am asking
  7. crutschow
    Mar 14, 2008
    13,505
    3,376
  8. bowlingo
    Jun 29, 2011
    162
  9. crutschow
    Mar 14, 2008
    13,505
    3,376
    I believe that's the same device my first reference op note discusses.
    If you want true isolation that circuit won't do. You need an added isolator as shown in the op note. Otherwise you can just power it from a DC supply within the circuit's voltage limits of operation.
  10. bowlingo
    Jun 29, 2011
    162
    Thanks for your help...can you help me out with the exact components?....I really would like to make this and test it
  11. crutschow
    Mar 14, 2008
    13,505
    3,376
    If you want a cookbook design here's a circuit shown in Figure 19 of this ap note.
    Edit: The circuit parts are readily available and low cost. It uses an optocoupler for high isolation between input and output.
