Need to know what kind of resistor i have.....
Discussion in 'General Electronics Chat' started by noobchip, Sep 28, 2011.
  1. noobchip
    Sep 28, 2011
  2. DerStrom8
    Feb 20, 2011
    2,428
    1,329
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I found a KTA1046 over at Alldatasheet:
    http://pdf1.alldatasheet.com/datasheet-pdf/view/423460/KEC/KTA1046_11.html
    You'll probably have to click here:
    http://www.alldatasheet.com/datasheet-pdf/pdf/423460/KEC/KTA1046_11.html
    and then click on the link to the right of "Download" to view it in your browser.
    [eta]
    Here's a direct link to a PDF datasheet from another site: http://doc.chipfind.ru/pdf/kec/kta1046.pdf
    It appears that Quest Components has some stock:
    http://www.questcomp.com/questdetai..._content=PartDetails&utm_campaign=FindchipsWS
    They have a $25 minimum order.
    Digikey carries these Sanyo transistors:
    http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=869-1064-ND
    Datasheet: http://media.digikey.com/pdf/Data Sheets/Sanyo Energy/2SB1274,2SD1913.pdf
    Looks to me like they're a pretty good match for yours. Power dissipation is 20w vs 25w which is somewhat of a concern; but they're $0.88/ea, and only have a few left.
  4. noobchip
    Sep 28, 2011
    @ derstrom8
    your right its a transistor sorry.
    @ sgtwookie
    my only concern is that the y numbers dont match. does it make a difference?
    Example the y number on my transistor says y017 and the ones that i found on your suggested sites say y709 or y136.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The Y numbers would be some kind of manufacturing date code.
  6. noobchip
    Sep 28, 2011
    cool. thank you guys for your help! gunna order them tonight.
  7. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    The letter and string of 3 digits is the lot number. The transistor itself should be the same as what's in the datasheet.
    Glad to help! :)
