Need to know about working of a fdw9926a part
Discussion in 'General Electronics Chat' started by deepak9709, Sep 19, 2013.
  1. deepak9709
    Sep 19, 2013
    Hello friends, I am working on a circuit, and i have got a part number FDW9926A which a dual n channet power trench MOSFET.
    But i am unable to know that how it works?
    If anyone know then please explain the working of that part.
  2. Jony130
    Feb 17, 2009
    3,995
    1,117
    Do you know how N channel MOSFET work?
  3. edmundopt
    Member
    May 4, 2011
    60
    Take a look at the datasheet, check for the pin 1 position.
    If you connect Drain(pin 8,1) to your load, Source (7,6,2,3) to ground and apply a voltage of 4.5volts to Gate(5,4) , you will get a RDS(ON) of 0.032ohm.
    If you check the datasheet, with 4.5volts at the Gate you will be able to supply 4.5amps to your load.
    Note that the power dissipation will be of 0.648Watts
  4. Dodgydave
    Jun 22, 2012
    5,172
    778
    datasheet
    looks like two transistors in an 8pin dil package
  5. deepak9709
    Sep 19, 2013
    i don't know exactly how it is working, becoz when i power up the left side (1,2,3,4) then i m getting output at the 2nd side ( 5,6,7,8).
    so i m confused about the working of n-channel mosfet to due to this propoerty, it is working like an opto-isolator.
  6. deepak9709
    Sep 19, 2013
    hello friends, i have attached a file which includes connectivity details and behavior description.
