Need to get rid of noise from DC motor. Help please.
Discussion in 'The Projects Forum' started by lidstrompl, Mar 16, 2012.
  1. lidstrompl
    Mar 16, 2012
    Hi. I'm running a small projects which involves finding current change due to various dynamic loads imosed on a DC motor. I'm using arduino with motor shield and 10k pot to adjust direction and speed of the motor. My motor is a 12V 30:1 gear DC (EMG 30)
    I'm using Picoscope for my scope and PicoLog to lod my data. I get tremendously large noise when I measure my voltages across. I have installed an 0.1 uF capacitor across the motor terminals and two 0.047 uF caps - across each lead and the motor casing (shied) - but it didn't help.
    Also, when using picoscope, what is the right way to connect the red and black clips across the motor - I may be doing it wrong (it does not allow to connect the two across the resistor as it gives the grounding effect).
    Excuse me for my poor electrical knowledge, but I hope some more experineced folks here woud give me some tips on how I can get rid of this noise.
  2. jimkeith
    Oct 26, 2011
    Tell us more about how you are powering this motor--certainly not a 10K potentiometer
    Sounds like the a PWM motor drive control
    What is the motor current rating and base speed?
    A simple low-pass filter for your voltage and/or current measurement may do.
  3. lidstrompl
    Mar 16, 2012
    Thanks for your response jimkeith.
    I'm using a 12 V DC supply from my AC-DC adapter.
    Yes PWM is used to control the drive.
    Rated current 530 mA Rated speed 170 rpm
    The thing is, PicoScope 2203 does not allow for a low pass filter... :(
    Here is the motor data:
    Any more suggestions??
