Need to find equivalent or bypass a cm3406ds
Discussion in 'General Electronics Chat' started by doug08, Oct 28, 2012.
  1. doug08
    Jan 30, 2011
    153
  2. SPQR
    Member
    Nov 4, 2011
    379
    48
    I can only find the chips on Chinese websites.
    I've attached to spec sheet for those interested.
    So it's an 8 pin step-down switch mode converter
    1.2A output current
    Pin out:
    1 - NC - not connected (well, that's good! one less lead to worry about)
    2 - BS - bootstrap - (cap to drive output voltage higher) sounds like BS to me:)
    3 - IN - Vin
    4 - SW - Vout
    5 - GND - ground
    6 - FB - feedback - resistor divider sets voltage output
    7 - Comp - compensation - something, something, something
    8 - EN shutdown enable - keep above 2.495 V and the thing is ON
    It looks like the same company makes something similar MP8716, but has a different pin out.
    I wonder if a simple 780X or a variable voltage regulator might work.
    Let's wait for other opinions.
