Need to find DATA.
Discussion in 'General Electronics Chat' started by R!f@@, Jan 16, 2013.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,793
    771
    Hey guys.
    My li-on charger went kaput. :mad:
    I found the component shown below dead short. It's a SOT-23 Package.
    No is as written N0190.
    I believe it is a transistor as I have a second charger.
    What I like to know is the DATA so I can replace it.
    Second problem i sthe below FET's
    These are fom a Y-SUS PCB & PSU of a 42" Panasonic Plasma TV.
    Just in case the last one starts with a R, i.e RJP30H2A.
    I have the nikos data (P1260ATF)
    Does any of the members know hot to get the specs of all the components.
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Here you are Lieutenant Commander Data :p
    But joking aside could it ne that the code is just N0(1) and the 190 is just some other info. In my Turuta databok I found some info about N0(1). Not that it is perfact in any way
    N0 BFR505T Si-npn SATV, 20V, 18mA, 150mW, B=60..250, 9GHz SOT-416 16ta - 3a Phi
    N0 ELM7640LAB Vdet-IC 4.0V±2%, -Reset PPO, 250ms SOT-23 16vdc VD7 3d Elm
    N0 R1100D201C LVR-IC U-low Icc, 2V±2%, 180mA SON1408-3 18vj VR1 3d Ric
    N0 R3111N502C Vdet-IC 5V±2%, -Reset ODO SOT-23 16vdd VD6 3d Ric
    N0 R3130N40DC Vdet-IC 4V, -Reset ODO, 200ms SOT-23 16vdc VD6 3b Ric
    N0 TC54VN3002ECB Vdet-IC 3.0V±2%, -Reset ODO SOT-23 16vdb VD6 3a Tcs
    N0 TN0200T n-MOSFET-e V-MOS, LogL, 20V, 0.73A, <0.44 SOT-23 16fh - 3a Six​
    N0 XC61CN3002M Vdet-IC 3V±1%, +Reset ODO SOT-23 16vdb VD6 3d Tor
    N0 XC6GN3002HR Vdet-IC 3.0V, +Reset ODO USP-3 17vdc VD1 9b Tor​
    N01 DDTC113TCA Si-npn-Digi Sw, 50V, 100mA, 200mW, 250MHz, R1=1k SOT-23 16ta - 3d Di
    N01 DDTC113TE Si-npn-Digi Sw, 50V, 100mA, 150mW, 250MHz, R1=1k SOT-523 16ta - 3d Di
    N01 DDTC113TKA Si-npn-Digi Sw, 50V, 100mA, 200mW, 250MHz, R1=1k SC-59 16ta - 3d Di
    N01 DDTC113TUA Si-npn-Digi Sw, 50V, 100mA, 200mW, 250MHz, R1=1k SOT-323 16ta - 3d Di
    N01 SST4391 n-FET Sw, Chopper, 40V, Idss=50mA, 350mW, Up<10V SOT-23 16fa - 3a Cal​
    R!f@@ likes this.
