Need to design a phase shift detector circuit... not sure how to start
Discussion in 'The Projects Forum' started by hrstar24, Nov 4, 2011.
  1. hrstar24
    Thread Starter Active Member
    Apr 7, 2009
    32
    So I need to build a phase shift detector circuit for my project, and I don't really know where to start.
    My project is basically dealing with phase shifts in a pulsing laser. I am going to pulse the intensity of the laser at a frequency of about 60 kHz in a sine wave. The laser then goes through a medium that slows it down, creating a phase shift. This phase shifted laser output then hits a photodiode which converts it back into an electrical signal. The phase shift detector will then recieve the original sine wave from the laser controller, and the shifted signal from the photodiode. I need the Phase Shift Detector to then translate the phase shift into some DC voltage that feeds into a micro controller.
    Inputs:
    A(t) = ACos(wt); Original wave form from laser controller
    B(t) = BCos(wt - phi); Wave form from photodiode
    My initial thinking was somehow multiplying these waves together, and then integrating them over 1 period of the wave. This way I can solve for phi, and use a simple function in the micro controller to convert the integration value into phi.
    I am not really sure how to multiply the two signals together, is there some circuit I can use or some trick with the photodiode maybe? For the integrator, I was just going to use an op amp circuit.
    Anyone got any suggestions on how to multiply the signals together? Or am I doing this phase shift detection in a complete wrong way? Is there a much simpler way to do this out there somewhere?
  2. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Convert the incoming waves to digital using a comparator for each wave, adjust the Vref for each wave until both waves are a digital square wave of 50:50 duty cycle.
    Then run both square waves through a AND gate, so output is high only when both waves are high. Then RC filter the output of the AND gate and DC voltage will be linear to phase shift.
  3. Jaguarjoe
    Apr 7, 2010
    770
    90
    I always did this stuff with XOR gates but that was a long time ago. Lots on the web about it.
    If you're feeding a micro, skip the DC conversion and just feed the gate's digital output directly into the controller.
    I think 74HC7046 chips have phase comparator circuits built in. Probably many more like it.
  4. t06afre
    May 11, 2009
    5,939
    1,222
  5. MrChips
    Oct 2, 2009
    12,624
    3,451
    You can create a phase detector using a D-type flip-flop.
  6. hrstar24
    Apr 7, 2009
    32
    Thanks for the help everyone
    So the RC filter at the end functions as a voltage integrator, but it outputs a triangle wave w/ a square wave input. So do I just make the cutoff frequency much lower than the 60 kHz my waveforms are at? Will this make the output DC voltage constant?
  7. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Yes, with the right filter values (large R and C) the output will be close enough to DC so the final output is a DC voltage linearly proportional to the phase shift. It's a common system in laser rangefinders.
  8. hrstar24
    Apr 7, 2009
    32
    Alright thanks.
    I have run into a quick snag, though. Turns out we will probably be operating at ~6 MHz now, not 60 kHz like I planned before. The op amp comparator no longer works correctly on such a high frequency, so should I look into buying a comparator chip that works at high speeds?
    Anyone got any recommendations for some relatively cheap chips I can get off digikey or sparkfun?
    I found this chip on the TI website, will it work?
    http://www.ti.com/product/tlv3501
  9. vidhyavs
    Oct 10, 2012
    Sir,
    We are using D flip flop logic for implementation of phase detector in PLL. But after resetting the output is oscillating. Can you suggest any solution.
    Thanking you.
