Need to create a ground
Discussion in 'The Projects Forum' started by Ricks.Radio.Conversions, Apr 12, 2015.
  1. Ricks.Radio.Conversions
    Apr 12, 2015
    Hi! I am taking an AM 8-track car radio and converting it to AM/FM. I need to use the track selector switch, it is a momentary switch, and turn it into a latching switch or use a relay to latch and unlatch a ground output.
    Any help would be great! Thank you.
  2. MrChips
    Oct 2, 2009
    12,636
    3,454
    You can do it with a logic circuit called a toggle flip-flop.
    Firstly, you need to debounce the momentary switch with a filter circuit and a Schmitt trigger.
    Then you apply the clean signal to the clock input of a T-type flip-flop (created from a J-K flop-flop). From the output of the flip-flop you can drive a transistor or a relay.
  3. Denesius
    Member
    Feb 5, 2014
    89
    14
    Don't know how complex you want to get, and whether you know enough to build the circuit recommended by MrChips, buy here's an alternative design. It uses simple circuit & cheap 12v relays:
    http://www.emil.matei.ro/onof2.php
  4. Ricks.Radio.Conversions
    Apr 12, 2015
    Denesius, thanks a lot! They all look good, but those end results are gating power. I need to gate the ground through, but I think I can manipulate it to work.
  5. Ricks.Radio.Conversions
    Apr 12, 2015
    Any chance you have a schematic for this?
  6. MrChips
    Oct 2, 2009
    12,636
    3,454
    Here is a conceptual circuit, not tested:
