Need to build this circuit - parts help (only passives)
Discussion in 'General Electronics Chat' started by Management, Apr 5, 2010.
  1. Management
    Thread Starter Active Member
    Sep 18, 2007
    306
    I need some help identifying a few parts that I can use in two different situations. First the circuit diagram:
    Inductors: 3
    Capacitors: 2
    Resistors: 2
    Terminations not included. For simulation purposes only.
    This is a line trap that blocks the frequency range. I hope to pass at most 120V at 4 Amps (50/60Hz). What kind of parts can I get and what rating must they have. Inductor, Capacitor, and Resistor types. So many to choose from.
    If I wanted to pass 15 Amps at 120V (50/60Hz) how would this change? Will it just be high rated components?
    Hopefully Digikey or Mouser has them?
    Thanks.
  2. Management
    Sep 18, 2007
    306
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
  4. Management
    Sep 18, 2007
    306
    Hey Bertus, I figured those can work as my line trap then. Is it possible to get some NEMA 5-15R to connect on both sides?
    I want to do this:
    AC Power --> Iso Transformer --> Line Trap --> Power Strip
    Any issues. I want to have that power strip isolated from the AC Mains because I will have some PLC Comm running on the power strip.
    I should be able to have some NEMA receptacles on both sides of the recommended line filters correct? It will serve as a high impedance to the MHz frequencies so it doesn't go back on the AC Power Mains in the lab.
