Need to build an isolated DC-DC converter. Topology etc?
Discussion in 'The Projects Forum' started by TBJ, Nov 11, 2013.
  1. TBJ
    Apr 9, 2012
    8
    I need to build an isolated DC-DC converter for a project. It's going to be a one-off so my requirements are mainly ease of building and simplicity.
    Requirements:
    - Low noise - it is going to be used in a class D amplifier
    - 12 volts in, 2 x 12 volts 1 amp out
    - Easy to wind transformer - not thousands of turns
    - Fully isolated output
    I know there are three topologies I should look at - flyback, push pull or forward. In layman's terms, what is the difference between these topologies and which one should I be looking at to suit my requirements?
    Cheers.
  2. bountyhunter
    Sep 7, 2009
    2,498
    507
    Reminds me of when National was getting ready to dump me after 20 years and my boss asked me to write down everything I knew.....
    FYI, Push-pull is a forward converter.
    Building DC-DC converters, designing the control loops, designing transformers, etc is not a topic which can be covered in a single forum thread. Lots of info on the net if you search.
    I still recommend you go to the TI website and research a simple switcher like the LM-2577 and let the computer design it and create a parts list.
