need to activate switch on application of wide ranging voltage (dc) and current
Discussion in 'The Projects Forum' started by dogfuel, May 4, 2010.
  1. dogfuel
    Apr 13, 2009
    10
    I'm not proud so feel free to laugh at my ignorance ...
    I need to close (or open) a switch upon the application or removal of a dc signal. If possible, I need to accommodate a wide range of voltages in the trigger signal 3.3 - 24v and an equally wide range of currents (from a few milliamps to 1 amp).
    If the trigger signal was constant, I'd use a transistor or ss relay (I can put 3v over the target switch if needed) but have no idea how to do this for an unknown signal. A reed relay?
    Thanks in advance
  2. mik3
    Feb 4, 2008
    4,846
    63
    Where is this signal coming from?
    You can use a comparator IC supplied by 24V DC and when the input voltage is above 3.3V it will control a relay (if its output current rating allows) or something.
  3. Engr
    Member
    Mar 17, 2010
    114
    5
    do you have a schematic diagram for this? You can try using a mosfet with a high current rating and a Vgs => 3.3V
    dogfuel likes this.
  4. dogfuel
    Apr 13, 2009
    10
    this is a general purpose input - it could be anything from an analog sensor 4-20ma (converted to 0v or voltage) to the electrical system of a piece of equipment. It may be impractical to do this but I'd like to covert 0v and any voltage at any current to a binary value by opening or closing a switch.
  5. Bychon
    Member
    Mar 12, 2010
    469
    41
    This description makes it even less likely that anyone can guess what you need.
  6. retched
    Dec 5, 2009
    5,201
    313
    If you want to convert a 0 to a 1, use an inverter, or Schmitt trigger.
    I am taking a guess here, but Im guessing the thing sending the signal is usually outputting 0v and when it outputs something other than 0v you want to operate a switch?
    Will a relay do?
    a LOT more info on your part would be helpful.
