View attachment 88075 I'm trying to build a transistor small motor controller but I realiz ed today that the noise that has been intermittently present is coming from the high bay lights in my shop. The problem is that I use a resistor in parallel with the transistor BE junction. Sometimes the noise is so high that it triggers the transistor to conduct. Any easy solution to fix or reduce this noise?
Thank you in advance.
