Hey guys I'm about to start a new project and am looking for some advice. I would like to build myself a two stage circuit that I can fit inside the body of my electric guitar. The first stage will be a distortion circuit, likely an op-amp or two and some diodes for clipping. The second stage will be a headphone amplifier so that I will be able to play the guitar without the need of a standalone amplifier.
I would like both circuits to have bypass functionality. My questions for the experienced are:
1. Best op-amps for this application, any audio op-amp do? noise, slew rate matter much for this frequency range/application? Hows the LM386 http://www.national.com/mpf/LM/LM386.html#Overview
2. Would 2 9V batteries provide enough juice for both circuits? Is it okay to power them both from the same power source? Would it work fine with just 1 9V split?
3. I want this to work with a full sized pair of koss headphones. How do I know how much gain I will need from the amplifier to drive a pair of headphones? I don't know much about this. Do I need a power amp?
Frequency Response 25-15,000 Hz
Impedance 32 ohms
Sensitivity 92 dB SPL/1mW
Distortion < 0.3%
CordStraight, Dual Entry, 8ft
I've found these stats for my headphones. I'm not really sure how to drive speakers.
There are volume and tone pots currently in the guitar. I plan on just cutting the wire to the output and routing it into this circuitry first and then to the output. I have a Dremel to cut out some of the body of the guitar to fit these electronics inside. Any help appreciated. I'm sure I will have more questions if I get any responses. Thanks!
Impedance 32 ohms
Distortion < 0.3%
