Need Suggestion For Lock !
Discussion in 'The Projects Forum' started by hzk17, May 3, 2013.
  1. hzk17
    Mar 20, 2013
    31
    I have asked for help in the forum regarding my circuit "One Transistor Based Lock" the feedback is really great, I have made this circuit about 3 times, now I have asked my teacher, he has allowed me to change the circuit, but it should be a lock. Now I should use Transistor, also now i am allowed to use a IC, but it shouldnt be a PIC. I am using a DPDT Relay 5V, when an incorrect combination is entered the buzzer will sound, and when the correct combination is entered a dc toy motor will be driven.
    So please direct me towards a circuit which will fulfill my need
    The Attached image of the circuit is the one which is worthless, the good people on this forum have pointed out the problems in the circuit diagram.
  2. joeyd999
    Jun 6, 2011
    2,758
    2,937
    Creating a new thread will not engender additional help. You already were asked to supply additonal info, but you did not:
    I will humor you though (and I hope a moderator will connect the threads).
    Your circuit should work. Can you tell us *how* it is not working?
    Here are some tips:
    1. Confirm your power supply is, in fact, outputting the correct voltage.
    2. Check continuity on your switch banks. The top set should be continuous when all switches are on, the bottom bank should be discontinuous when all switches are off.
    3. Measure Vb (the transistor base voltage with respect to ground). It should be 0 volts when the incorrect code is entered, and about .6 or .7 volts when the correct code is entered.
    4. Measure Vc (the transistor collector voltage with respect to ground. It should be equal to the power supply when the incorrect code is entered (assuming the relay is connected!), and about 0.1V when the correct code is entered.
    5. Measure the voltage across the relay coil terminals. It should be equal to the power supply (less about 0.1V) when the correct code is entered, and about 0V when the incorrect code is entered.
    hzk17 likes this.
  3. hzk17
    Mar 20, 2013
    31
    @joeyd999 Sgt.Rookie, he said in the earlier post as the diode cathode is on the +ve rail so if the supply is given inversely the diode would be Forward Biased, and therefore it would fry the transistor.
  4. kubeek
    Sep 20, 2005
    4,691
    806
    Do you mean that if you reverse the supply polarity the transistor will fry? Yes that could happen, so that is why you don´t want to put reverse voltage into anything that isn´t specifically made to cope with it.
    joeyd999 and hzk17 like this.
  5. hzk17
    Mar 20, 2013
    31
    you are right
  6. joeyd999
    Jun 6, 2011
    2,758
    2,937
    Thanks. I missed that post (and, apparently so did OP).
  7. hzk17
    Mar 20, 2013
    31
    @joeyd999, my friend has made the circuit about which i am talking now we want to add a magnet, a miniature door would be added when the correct sequnece will be entered we want to demagnetize the holder or stopper of the door so that it could be opened. Can you tell me what is device called or do we have to magnetize some piece of steel or something.
  8. kubeek
    Sep 20, 2005
    4,691
    806
    If I understand you correctly, you want an electromagnet attached to the door frame that holds a metal piece attached to the door until you enter the correct code, right?
    hzk17 likes this.
  9. joeyd999
    Jun 6, 2011
    2,758
    2,937
    I know what you are talking about, but not what it's called. Sorry. But, essentially it is an electromagnet installed in the door jam, along with an iron plate attached to the door. Activating the magnet "locks" the door shut. Deactivating it allows the door to be opened. They are neat because there is no sound or click when the magnet is released, and there are no visible door latches.
    hzk17 likes this.
  10. kubeek
    Sep 20, 2005
    4,691
    806
    As I remember these magnets from an RFID card operated door lock, they make a huge clang when the magnet is already activated and the door closes, so it may not be as neat in certain arrangements. And with the lock hzk17 has this will happen as it has no delay.
    hzk17 likes this.
  11. hzk17
    Mar 20, 2013
    31
    right @kubeek
  12. hzk17
    Mar 20, 2013
    31
    guys if you have any idea what would be this device called, please tell me ASAP
  13. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Oh, the irony! ;) :D
  14. joeyd999
    Jun 6, 2011
    2,758
    2,937
    The ones I've seen (on professional office buildings) were able to sense when the door closed, and would then activate the magnet silently.
