Need some simple help with a scope filter
NashvilleFiero
Joined Jun 28, 2008
Hey Guys!
This is my first post.
I know this circuit is fairly simple, but I need some help. I need a circuit to put in line with my test leads so that I can filter out the DC signal from a car alternator. I can look at the waveform on my Snap-On scope.
Can anyone help?
Thanks!
Brit
SgtWookie
Joined Jul 17, 2007
22,230
All you really need is a small capacitor, perhaps 1uF. If you use an electrolytic, have the + side towards the alternator wiring. A poly cap would be much better. If your scope has extremely high input impedance, you may need a resistor to ground (say, 47k) on the output of the cap.
Capacitors block DC, but allow the effects of AC to pass right through.
See the attached for a simulation of a portion of an alternator, the bridge rectifier, outputs along the way, and the C1/R1 combination I've mentioned. Notice that the simulated O-scope trace from point (E), the green trace is virtually the same as the original output (D), the yellow trace, but is settling down to become centered around 0v; which you need to help diagnose problems with the rectifier bridge or the diode trio/exciter diode.
NashvilleFiero
Joined Jun 28, 2008
Great info. Thanks!
