need some info about the logic circuits
Discussion in 'Homework Help' started by shaider530, Feb 9, 2008.
  1. shaider530
    Jul 7, 2007
    6
    hi! Please help me, my prof. gave us a simplified boolean expression. (F= AC + BCbarD). And he wants to convert it into a logic circuits using NAND gates only.
    What would be the easier way to solve that problem.
    Or better yet what is the answer? (At least the simplified boolean expression using NAND gates.)
    Thanks...,:)
  2. scubasteve_911
    Dec 27, 2007
    1,202
    I'm kind of rusty at doing boolean reduction, I usually stick to K-maps, but I gave it a shot.
    F= AC + BC'D
    = (AC + BC'D)"
    = ((AC)'(BC'D)')'
    AC are inputs to a 2-input NAND1
    C is a shorted input to a 2-input NAND2 (make an inverter)
    C'BD are inputs to a 3-input NAND3
    I think I'm right, but I could be wrong
    Steve
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    The Boolean reduction is correct. You need one more 2-input NAND gate whose inputs are from the outputs of NAND1 and NAND3.
    The trick to these questions is as follows:
    1. Where relevant take out an common factors (this didn't need to be done in this question).
    2. If relevant use the double NOT for the whole function, i.e. F => {NOT gate} => NOT(F) => {NOT gate} => NOT(NOT(F)) = F. Why do you need to do this? Consider DeMorgans theorems (part 3).
    3. Apply DeMorgans theorems, in particular (A + B)' = A'B'. DeMorgans may need to be applied several times to remove the OR operands.
    4. Remember you can create a NOT gate using a NAND gate by tying the inputs together (as Steve states above).
    Dave
  4. scubasteve_911
    Dec 27, 2007
    1,202
    Oh yeah, my bad? :p
