Need some help
Discussion in 'Electronics Resources' started by jchino28, May 7, 2010.
  1. jchino28
    Mar 3, 2008
    I need some help with this circuit diagram from this datasheet. for two different LED configurations. One is a single led the other other is two LED.
    Both are the same correct, only difference is the two LED will flash the two color.
    FYI This is a RJ45 connector same footprint, but different LED config.
    ma1991 likes this.
  2. R!f@@
    Apr 2, 2009
    8,785
    771
    What you are asking for is not clear.
    and post the schematic if you use any
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It would help if you posted a link to the datasheet.
    I don't see any current limiting resistors on the LEDs. Without them, the LEDs will likely become damaged.
