need some help...
Discussion in 'The Projects Forum' started by mtnokh, Sep 6, 2009.
  1. mtnokh
    Sep 11, 2008
    10
    hey guys how r u all doing? I have a project which asking for building a function generator that has to run for 4 different frequencies....I don't know to to start that....if u guys can give me some steps to begin with I would be really thankful......
    mtnokh
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    You'll need to provide a bit more input. 4 frequencies at once? What kind of waveforms, and signal amplitude?
  3. mtnokh
    Sep 11, 2008
    10
    well it has to run 1,2,4,10 Hz and three kinds of wave (rectangular,square) i really need some help guys....thanks
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Once again - do the frequencies have to come out all at the same time?
    What are the three waveforms? Possibly square, triangle and sine?
    Any other requirements? Is this a class assignment?
  5. Gustav180
    Member
    Aug 25, 2009
    17
    You can do it easy, look at the chip XR2206. This is a complete function generator chip.
    You can do it cheap. Use one CMOS hex inverter as CD4069 and around this you can design a sinewave generator and then square the sinwave and then integrate the squarewave to a triangular wave. All with the same chip.
    You can do it complex, use a PIC-processor and generate the waveforms through a DAC.
    Best regards
    Gustav
  6. hgmjr
    Jan 28, 2005
    9,030
    214
  7. mtnokh
    Sep 11, 2008
    10
    thank you guys so much that was a big help.......
