Need some help with triggering an LED circuit
Discussion in 'General Electronics Chat' started by outsider787, Nov 11, 2011.
  1. outsider787
    Nov 11, 2011
    I have an input signal which is either 3V or 0V.
    From a battery I need to drive an LED with this signal.
    I need the LED to be on when the signal is at 0V and I need the LED to be off when the signal is at 3V.
    Anyone have any idea how I can wire this up?
    Thanks,
    adrian
  2. Bernard
    Aug 7, 2008
    4,236
    414
    A one transistor invertor should do for a red LED @ 20 mA. One k Ω base R, 50 +- Ω for LED current limiting. 2N3906 or similar.
  3. outsider787
    Nov 11, 2011
    Perfect.
    Exactly what I've been looking for.
    http://www.kpsec.freeuk.com/trancirc.htm#inverter
    Thank you!
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    Is the transistor used to short the LED to turn it off when the 3V is present?
  5. outsider787
    Nov 11, 2011
    From what I understand, yes, the transistor is used to short out the LED (through a resistor) when the 3V is present.
    why do you ask?
  6. Bernard
    Aug 7, 2008
    4,236
    414
    Ouch: Shorting the LED would be quite wastefull of battery life.' should have mentioned that 2N3906 is PNP. As they say, apicture is worth a 1000 words.
  7. sheldons
    Oct 26, 2011
    616
    101
    Heres some led drivers(for info ...)
  8. Audioguru
    Dec 20, 2007
    9,411
    896
    BUT with a 3.5V blue or white LED their current is only 6mA.
