Use caution with Ra. I recommend as a "rule of thumb" to always have at a minimum 100 Ohms per 1v of Vcc. If Vcc=6v, use 600 Ohms or more. If you go much lower than that, you will let the magic smoke out of the 555 timer.
1N914 diodes are equivalent to 1N4148 diodes. They have a maximum current rating of 100mA. As the current through them increases, so does their Vf (forward voltage).
See the attached graph, which illustrates the Vf of a typical 1N914/1N4148 over a range of current flow.
