Ok.... I have been reading a lot of sites and how-to to do this.
I'm wanting to make several green led's throb from very dim to full bright. I don't want them to go completely out. I want to use a TLC555 or if i have to 556CN. the green leds are 3.5v @20mA. I would also like to have a switch or button implemented to activate it and turn it off.
I'm thinking of setting the 555 up with a 50% duty cycle and using a trimpot to set the desired rate for the throbbing. im just unsure of the correct uF caps and NpN or PnP to use. I have a breadboard for set up and testing. i would like to either use a 6v drycell for power or impliment a wall wart that is 5vdc @ 2000mA output.
