need some help for this problem please
Discussion in 'Math' started by benn, Apr 20, 2009.
  1. benn
    Apr 20, 2009
    (a) A body of mass m kg is attached to a point by string of length
    1.25 m. If the mass is rotating in a horizontal circle 0.75 m below the
    point of attachment, calculate its angular velocity.
    (b) If the mass rotates on a table, calculate the force on the table when
    the speed of rotation is 25 rpm and the mass is 6 kg.
  2. ygrignon
    Jul 30, 2008
    a) first the geometry: we have a rectangular triangle formed by the radius of rotation, the distance between the attach point of the string and the plane of rotation and the string. Solving that gives a radius of rotation of 1 m.
    Then the mechanic: the centripetal acceleration on the mass is radius * angular velocity squared. This is pulling horizontally and gravity is pulling down. The ratio of these two is in line with the string and is 1 m / 0.75 m = (radius * angular velocity squared) / g
