Need some help converting an audio signal (speaker wir output) into a square wave.
Discussion in 'General Electronics Chat' started by Michael Carlotta, Sep 25, 2014.
  1. Michael Carlotta
    Sep 25, 2014
    I am trying to get the compression side of an audio signal's sine wave into a 9V pulse and the decompression side of an audio signal's sine wave into a 9V pulse (not shown well in the sketch but I would use a cyclic relay).
    I'm sure my sketch will get a chuckle out of you.
    Thanks for any help.
  2. crutschow
    Mar 14, 2008
    13,505
    3,376
    At what point on the audio signal do you want the pulses to occur? You diagram seems to indicate it's near the peaks.
    Compression and decompression have nothing to do with the signal polarity. Normally the top of the waveform is called the positive side and the bottom of the waveform, the negative side.
  3. wayneh
    Sep 9, 2010
    12,391
    3,246
    Window comparator. Turn on compression when voltage falls outside the window. (At least that's what I'm guessing you meant from your wording.)
  4. Michael Carlotta
    Sep 25, 2014
    OK thanks Ill have to google that.
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    You might want to have a look at the TCA965.
    I have used the chip in the past.
    Bertus
  6. ian field
    Distinguished Member
    Oct 27, 2012
    4,456
    792
    Last time I tried to buy a TCA965, I was told it was obsolete - and that was years ago.
    The 555 has a window comparator input, but the thresholds are fixed at 1/3 & 2/3 of Vcc by an internal series chain of 3x 5k resistors - you can exert a certain amount of "pull" on the lowest resistor via the CV pin, manipulating Vcc to influence the upper threshold can get a bit fiddly.
