Need some correction on an image.
Discussion in 'Feedback and Suggestions' started by R!f@@, Jul 19, 2012.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,785
    771
    Referring to this page
    The first image shows meter readings as 0V in forward bias condition. This is not true if the transistor is OK.
    I am telling this as n00bs might confuse this with correct reading as such.
    I think it is best to show the meter in diode check mode rather than in R checking mode.
  2. ErnieM
    Apr 24, 2011
    7,434
    1,625
    Since the meter is in the resistance mode the reading is 0 ohms, not volts.
    This happens to be correct.
    If you would read all the way down to the second paragraph you would find the author shares that same opinion.
