Need SOIC, SSOP convreter design
Discussion in 'The Projects Forum' started by embpic, May 29, 2014.
  1. embpic
    May 29, 2013
    187
    i am looking for some converter for SOIC, SSOP to try it at home. i have some IC's and need to try some protoytype works.
    so help me for design or post the if any have design such PCB's.
  2. alfacliff
    Dec 13, 2013
    2,449
    428
  3. Veracohr
    Jan 3, 2011
    559
    77
  4. ErnieM
    Apr 24, 2011
    7,436
    1,626
    Go to EBay and type in the package size plus "adapter". Wade thru the results. Most places will be in China or the Philippines and sell these things for dirt cheap good quality, plus free (slow) shipping.
    I keep plenty in stock in advance of need.
  5. embpic
    May 29, 2013
    187
    Thank you sir but i was looking for making it at home to do some kinda R&D.
  6. embpic
    May 29, 2013
    187
    if u provide pcb layout it could be better.
  7. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    total waste of time to make SMD adapter yourself.
  8. absf
    Dec 29, 2010
    1,493
    374
    I tried once making my own PLCC-44 on single-sided PCB and it was huge. I agreed with takao21203 that it is a waste of time. I bought many of the adaptors from eBay Thailand, China and some locally.
    Allen
  9. takao21203
    Apr 28, 2012
    3,578
    463
    Think each hour of your time is worth $20, $50, $100.
    Even soldering a USB socket and looking up the pin connections costs you more dollars than a ready-assembled adapter PCB.
  10. absf
    Dec 29, 2010
    1,493
    374
    Further more, unless you can make double-sided PCB with plate through holes, the single-sided adaptor PCB tends to be very weak. After using it for a few times on the breadboard, all the solder connections are becoming shaky.
    Allen
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It's not just the time spent in trying to make adapters yourself; it's the many hours lost trying to troubleshoot problems due to those very same adapters being defective.
    absf likes this.
  12. ErnieM
    Apr 24, 2011
    7,436
    1,626
    To actually answer embpic's question, the ones I use typically look like so:
    They have a different pattern on each side for SOIC and SSOP devices.
