Need simple boost reference
Discussion in 'General Electronics Chat' started by tuuluser, Oct 11, 2013.
  1. tuuluser
    Nov 20, 2011
    23
    I need to add a 15V dc reference voltage to board. I'm going to compare it to some other signals through an ADC for calibration purposes. 20mA would be plenty.
    I only have 12VDC on the rail. I can get a small 2577 boost module on Ebay for less than 3 bucks that will do the step-up, but it takes up a lot of space and is about 15x more power than I need. Seems like overkill.
    Is there a small, low component count way for me to do the step up with an IC?
    Accuracy needs to be about 0.5%.
  2. bountyhunter
    Sep 7, 2009
    2,498
    507
    You could make a free running boost with a 555, a 2N3904 and an inductor with a zener clamp on the output.
    I made one that boosts 1.5V to 13V, use the same idea.
    tuuluser likes this.
  3. tuuluser
    Nov 20, 2011
    23
    I like this idea. Only issue is that the most stable rail I have is about 10VDC, so I would have to adjust at least R1 and beef up the zener.
    While looking up the parts on Digikey, I found the LMV431. Looks like this with a couple of resistors might be all that I need. All for less than a buck.
  4. tuuluser
    Nov 20, 2011
    23
    The LMV431 won't work, does not boost input voltage.
    Back to bounthunter's tip.
  5. THE_RB
    Feb 11, 2008
    5,435
    1,305
  6. #12
    Nov 30, 2010
    16,705
    7,358
    Some pre-fab modules:
  7. ronv
    Nov 12, 2008
    3,404
    1,496
    Or if you like capacitors.
    If you were just funning about the .5% you can replace the 431 with a zener. :D
