need simple 5v ~50Hz AC ouput for LCD
Discussion in 'The Projects Forum' started by elRey, May 18, 2009.
  1. elRey
    Thread Starter Active Member
    Feb 23, 2009
    65
    I have an unknown 4 segment (clock) LCD that was driven by a PCF8576CT. I've located the four baseplates and now need to identify the common segment pins for the LCD. So I just need a simple circuit I can use the output to discovery, thru trial and error, the segment pins on the LCD.
    i.e. touching one lead to one baseplate and then touching the other lead to each of the other non-baseplate pins and noting which segments activate.
    Thanks,
    Rey
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    An LM555 free-running oscillator should give you the clock.
  3. elRey
    Feb 23, 2009
    65
    Thank you. That will give me a 0-5v wave. Now how do I get a -5v to +5v wave?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If you have the +/- 5 volt lines, run the 555 with -5 to the ground pins and +5 to the positive ones. That should give you the +5 to -5 pulse.
  5. elRey
    Feb 23, 2009
    65
    Ah, I don't have the -5v line. I'm testing on a Electronic Lab with +1.5v, +3v, +4.5v, +6v, +7.5v, and +9v lines and gnd. How can I create a -5v line?
    Thanks again for you help.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Not to sound snippy, but you need -5 volts. One way to get there is with an ILC7660 charge pump. It outputs the negative equivalent of the positive voltage fed to it.
    Your LCD may run okay with +/- 4.5 volts, or +/- 6 volts.
    here's a link to a data sheet on the 7660 - http://www.intersil.com/cda/deviceinfo/0,0,ICL7660,0.html
  7. elRey
    Feb 23, 2009
    65
  8. Bernard
    Aug 7, 2008
    4,242
    418
    Just leave out C3
  9. elRey
    Feb 23, 2009
    65
    Thank you! I will try it tonight.
  10. Bernard
    Aug 7, 2008
    4,242
    418
    Is the display ground floating? If it is , might connect two resisters,around 1k, in series from 555 output to ground, and use center as ground, boost 555 operating V to 10V. Should then have +5 &-5 square waves refferenced to center tap.
  11. CDRIVE
    Jul 1, 2008
    2,223
    99
    Curious why?
  12. Bernard
    Aug 7, 2008
    4,242
    418
    With C3, approx. -5V DC out; wi th-out C3, -5V square wave.
  13. CDRIVE
    Jul 1, 2008
    2,223
    99
    OK, I must have misread something because I thought he wanted -5VDC.
    Thanks Bernard.
