Need RF transceiver for 200 meter,500 meter,1 km range
n1spx
Joined Sep 23, 2010
I'm sure someone else will ask more, but lets start with this:
What format is the data in? Analog? Digital?
How much data, how fast? bits per second would be a good measure.
Chuck, N1SPX
Papabravo
Joined Feb 24, 2006
21,225
Dear friends,
Please suggest RF modules for or 200 meter,500 meter,1 km range .
Low cost module is preferable..
Thanks in advance.
You really don't get to select the range. You pick a band, a power level, and an antenna. Sometimes the propagation will allow you to get the range you want and sometimes it won't. So you need a plan B.
RF and low cost don't usually go together, but you can dream.
THE_RB
Joined Feb 11, 2008
5,438
If you google for "RF module 1km range" etc you should find lots of products.
It's good to spend 20 minutes doing your own searching, then when you have some modules in mind you can ask people "has anyone used this module?" or "is this module any good?" etc. :)
