I needed a rectifier that could handle 400A and up to 15Vdc and they were pretty pricy. I came across this and am curious if it will do what I need.
http://www.ebay.com.au/itm/MSC-Mil-Spec-High-Current-800A-100V-3-Tab-Rectifier-652-887-Cost-135-00-/230841648737?hash=item35bf3c0661:g:8BUAAOSwT6pVlsDt
After some digging I found this page linked to the part/rectifier
https://nationalstocknumber.info/part-number/6096952-1_010309477
here is info from that data page:
Technical Definition
Rectifier, Semiconductor Device, U, also referenced with federal logistics item name code 62108 - Two or more diode semiconductor devices designed to function as a unit in changing alternating current to direct current. the diode devices are internally connected in series, and are permanently cased, encapsulated, potted, or molded together to form an inseparable unit. these units may be designed as either half-wave or full-wave rectifiers and may be mounted to form either single phase or three phase bridges. for interconnected items arranged in stack(s), see rectifier, semiconductor device. for items fabricated in the form of a monolithic or thin film structure that perform the function of a circuit, see integrated circuit (as modified). excludes semiconductor devices, unitized; semiconductor device assembly; and rectifier network, unitized.
Technical Characteristics
Absolute Maximum Current Rating Per Characteristic (ALAY):
800.00 amperes peak forward surge current
Absolute Maximum Voltage Rating In Volts Per Characteristic (ALAW):
100.0 peak inverse voltage
Circuit Connection Style Designator (AJUR):
Center tap 1 phase
Mounting Method (AXGY):
Threaded hole
Operating Temp Range (AFGA):
-55.0/+200.0 deg celsius
Overall Height (ABKW):
0.750 inches nominal
Overall Length (ABHP):
1.500 inches nominal
Material (MATT):
Silicon
Overall Width (ABMK):
1.200 inches nominal
Terminal Type And Quantity (TTQY):
3 tab, solder lug
Center tap 1 phase
Threaded hole
Material (MATT):
Silicon
3 tab, solder lug
