I am creating a (very small) buck converter for a custom (very bright) flashlight. I need to take the ~7 volt output from 2 LiPOs and drop that down to the point it produces a constant current of 9A across an SST-90 LED (A very powerful 3.6v/9A LED)
The space is limited (this PS has to fit into a cylinder about 10mm tall and 30mm in diameter) AND I need to fit a microcontroller in it as well (I'm using the ATtiny44A) The reason for the uC is to monitor temperature and allow me to program a interface to change the total power to the IC via PWM.
I have found an inductor that fits - 4.7uH at 10A. It takes up about 1/5 of the space. Since space is an issue, I can handle efficiencies of around 80%. I have this thing attached to a fairly large heatsink (the body of the flashlight).
I first thought I can use the ATtiny to handle the switching but soon discovered from reading forums that it can be very difficult to do that. I'm looking for a cheap (and small) IC that can basically take a voltage from a sensor resistor (0.005 ohm) and adjust the duty cycle accordingly. Since I would like to control it via PWM, I will need a way to enable and disable the supply.
Does anyone have any ideas or have advice on what to look for? Any help is greatly appreciated!
