that seems reasonable. some of the companies i searched were over $30 per board. i found a couple online places that do prototypes, if the order is under 50 ish they will do it cheap. since i will do all the assembly, and all im looking for is a bare board, no silk screen or solder mask, they should be reasonable. thanx for the heads up anyway!!I don't know if its any help to you but we normally budget anywhere from $1200.00 to $5000.00 for a PC Board turn including layout, fab and assembly of some small quantity.
Which was my point. How hard is it to draw something like this?Vito, that is a truly horrible drawing. If you're serious, you need to think about whether you're conveying useful information or not.
thanx, for the info, ill keep you in mind, i was thinking it might end up at a number like that. for now i wont need it, i need to make prototypes for distributers to test, and if i start getting big orders, ill let you know. its definetly worth it to have a professional board.When you get the design/schematic/parts list finalized I can do the layout and provide you with the gerber files for a PCB house. Looking at what you have posted so far I'd charge $300 to $500 to layout the board and provide gerber files.. We can set it up so you can use something cheap like Itead for the boards http://iteadstudio.com/store/index.php?main_page=index&cPath=19_20
by Aaron Carman
by Jake Hertz
by Jeff Child
