Need op-amp characteristics
Discussion in 'The Projects Forum' started by l1nuxg33k, Nov 5, 2006.
  1. l1nuxg33k
    Sep 27, 2006
    7
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Why not get the data sheeet on a MAX406? It has all that information. You will be able to set gain in the same manner as any op amp. If you want something better, check out a OPA134. you get an order of magnitude better input impedance.
    What kind of probe are you using? The standard calomel electrode puts put 59.2 mv/pH unit. Your full-scale outout should be +/-414.4 mv.
  3. l1nuxg33k
    Sep 27, 2006
    7
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
