Need online resources to help me with 8051 calculator project.
THCynical
Joined May 5, 2014
26
I have recently been assigned a 8051 calculator project.
Figure it out for yourself type assignment, We were given no notes/lectures on coding.
I'm not sure where to begin.
I'm looking for Online resources to help me with this project.
How to write basic code in C in general.
And stuff specially relating 8051 as a calculator.
The starting point for this project is from:
http://saeedsolutions.blogspot.ie/2012/06/interfacing-keypad-with-8051at89c51-c.html
I have ISIS 8 and Keil5 on the laptop.
Final note - I have looked online for a while for videos and sites to help me but my search terms are to general as i don't know what I'm looking for.
Thanks for your time.
THCynical
Joined May 5, 2014
26
well that's exactly what I'm looking for
do i put "#include" just before "Char key"?
Thanks your after saving me allot of time.
If anyone knows of good online resources that will help me so i know what I'm doing, i would love to see them.
shteii01
Joined Feb 19, 2010
4,644
You can download the C code from that blog entry. The download link is in the end of the blog entry.
http://dl.dropbox.com/u/22020714/8051 Calculator Code.rar
Code:
// Project:   Calculator
// Author:    M.Saeed Yasin
// Module description:  4 function single positive digit calculator
#include<reg51.h>
#include<string.h>
//Define Macros
#define Error  13    // Any value other than 0 to 9 is good here
//Function declarations
void cct_init(void);
void delay(int);
void lcdinit(void);
void writecmd(int);
void writedata(char);
void writeline(char[]);
void ReturnHome(void);
char READ_SWITCHES(void);
char get_key(void);
int get_num(char);
char get_func(char);
void DispError(int);
void disp_num(int);
//Pin description
P2 is data bus
P3.7 is RS
P3.6 is E
P1.0 to P1.3 are keypad row outputs
P1.4 to P1.7 are keypad column inputs
// Define Pins
sbit RowA = P1^0;     //RowA
sbit RowB = P1^1;     //RowB
sbit RowC = P1^2;     //RowC
sbit RowD = P1^3;     //RowD
sbit C1   = P1^4;     //Column1
sbit C2   = P1^5;     //Column2
sbit C3   = P1^6;     //Column3
sbit C4   = P1^7;     //Column4
sbit E    = P3^6;     //E pin for LCD
sbit RS   = P3^7;     //RS pin for LCD
// Main program
int main(void)
   char key;                     //key char for keeping record of pressed key
   int num1 = 0;                 //First number
   char func = '+';              //Function to be performed among two numbers
   int num2 = 0;                 //Second number
   cct_init();                   //Make input and output pins as required
   lcdinit();                    //Initilize LCD
   while(1)
     //get numb1
     key = get_key();
     writecmd(0x01);            //clear display
     writedata(key);            //Echo the key pressed to LCD
     num1 = get_num(key);       //Get int number from char value, it checks for wrong input as well
     if(num1!=Error)            //if correct input then proceed, num1==Error means wrong input
         //get function
         key = get_key();
         func = get_func(key);            //it checks for wrong func
         if(func!='e')                    //if correct input then proceed, func=='e' means wrong input
             //get numb2
             key = get_key();
             num2 = get_num(key);         //Get int number from char value, it checks for wrong input as well
             if(num2!=Error)              //if correct input then proceed, num2==Error means wrong input
                 //get equal sign
                 key = get_key();
                 if(key == '=')           //if = is pressed then proceed
                     switch(func)         //switch on function
                     case '+': disp_num(num1+num2); break;
                     case '-': disp_num(num1-num2); break;
                     case 'x': disp_num(num1*num2); break;
                     case '/': disp_num(num1/num2); break;
                 else                      //key other then = here means error wrong input
                     if(key == 'C')       //if clear screen is pressed then clear screen and reset
                        writecmd(0x01);   //Clear Screen
                     else
                        DispError(0);       //Display wrong input error
void cct_init(void)
    P0 = 0x00;   //not used
    P1 = 0xf0;   //used for generating outputs and taking inputs from Keypad
    P2 = 0x00;   //used as data port for LCD
    P3 = 0x00;   //used for RS and E
void delay(int a)
   int i;
   for(i=0;i<a;i++);   //null statement
void writedata(char t)
   RS = 1;             // This is data
   P2 = t;             //Data transfer
   E  = 1;             // => E = 1
   delay(150);
   E  = 0;             // => E = 0
   delay(150);
void writecmd(int z)
   RS = 0;             // This is command
   P2 = z;             //Data transfer
   E  = 1;             // => E = 1
   delay(150);
   E  = 0;             // => E = 0
   delay(150);
void lcdinit(void)
  ///////////// Reset process from datasheet /////////
     delay(15000);
   writecmd(0x30);
     delay(4500);
   writecmd(0x30);
     delay(300);
   writecmd(0x30);
     delay(650);
   writecmd(0x38);    //function set
   writecmd(0x0c);    //display on,cursor off,blink off
   writecmd(0x06);    //entry mode, set increment
void ReturnHome(void)     /* Return to 0 cursor location */
   writecmd(0x02);
   delay(1500);
void writeline(char Line[])
   int i;
   for(i=0;i<strlen(Line);i++)
      writedata(Line[i]);     /* Write Character */
   ReturnHome();          /* Return to 0 cursor position */
    RowA = 0; RowB = 1; RowC = 1; RowD = 1;     //Test Row A
    if (C1 == 0) { delay(10000); while (C1==0); return '7'; }
    if (C2 == 0) { delay(10000); while (C2==0); return '8'; }
    if (C3 == 0) { delay(10000); while (C3==0); return '9'; }
    if (C4 == 0) { delay(10000); while (C4==0); return '/'; }
    RowA = 1; RowB = 0; RowC = 1; RowD = 1;     //Test Row B
    if (C1 == 0) { delay(10000); while (C1==0); return '4'; }
    if (C2 == 0) { delay(10000); while (C2==0); return '5'; }
    if (C3 == 0) { delay(10000); while (C3==0); return '6'; }
    if (C4 == 0) { delay(10000); while (C4==0); return 'x'; }
    RowA = 1; RowB = 1; RowC = 0; RowD = 1;     //Test Row C
    if (C1 == 0) { delay(10000); while (C1==0); return '1'; }
    if (C2 == 0) { delay(10000); while (C2==0); return '2'; }
    if (C3 == 0) { delay(10000); while (C3==0); return '3'; }
    if (C4 == 0) { delay(10000); while (C4==0); return '-'; }
    RowA = 1; RowB = 1; RowC = 1; RowD = 0;     //Test Row D
    if (C1 == 0) { delay(10000); while (C1==0); return 'C'; }
    if (C2 == 0) { delay(10000); while (C2==0); return '0'; }
    if (C3 == 0) { delay(10000); while (C3==0); return '='; }
    if (C4 == 0) { delay(10000); while (C4==0); return '+'; }
    return 'n';               // Means no key has been pressed
char get_key(void)           //get key from user
    char key = 'n';              //assume no key pressed
    while(key=='n')              //wait untill a key is pressed
        key = READ_SWITCHES();   //scan the keys again and again
    return key;                  //when key pressed then return its value
int get_num(char ch)         //convert char into int
    switch(ch)
        case '0': return 0; break;
        case '1': return 1; break;
        case '2': return 2; break;
        case '3': return 3; break;
        case '4': return 4; break;
        case '5': return 5; break;
        case '6': return 6; break;
        case '7': return 7; break;
        case '8': return 8; break;
        case '9': return 9; break;
        case 'C': writecmd(0x01); return Error; break;  //this is used as a clear screen and then reset by setting error
        default: DispError(0); return Error; break;     //it means wrong input
char get_func(char chf)            //detects the errors in inputted function
    if(chf=='C')                   //if clear screen then clear the LCD and reset
        return 'e';
    if( chf!='+' && chf!='-' && chf!='x' && chf!='/' )  //if input is not from allowed funtions then show error
        DispError(1);
        return 'e';
    return chf;                        //function is correct so return the correct function
void DispError(int numb)           //displays differet error messages
    switch(numb)
    case 0:     writeline("Wrong Input");      break;
    case 1:     writeline("Wrong Function");   break;
    default:    writeline("Wrong Input");      break;
void disp_num(int numb)            //displays number on LCD
    unsigned char UnitDigit  = 0;  //It will contain unit digit of numb
    unsigned char TenthDigit = 0;  //It will contain 10th position digit of numb
    if(numb<0)
        numb = -1*numb;  // Make number positive
        writedata('-');     // Display a negative sign on LCD
    TenthDigit = (numb/10);              // Findout Tenth Digit
    if( TenthDigit != 0)              // If it is zero, then don't display
        writedata(TenthDigit+0x30);      // Make Char of TenthDigit and then display it on LCD
    UnitDigit = numb - TenthDigit*10;
    writedata(UnitDigit+0x30);      // Make Char of UnitDigit and then display it on LCD
