Need of Filters
Discussion in 'Homework Help' started by Manoj Sahu, Sep 29, 2014.
  1. Manoj Sahu
    Sep 29, 2014
    8
    What is the need of Filters in Rectifier circuits. Please explain in detail and if possible with diagram
  2. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,511
    Depends on the application, for power supply circuits look up % ripple, filters can include both or either Capacitor and inductor.
    Max.
    Manoj Sahu likes this.
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    The goal of rectification is to convert AC to DC. If there is no energy storage between the rectifier and the DC load, the pulsing DC voltage across the load will sag below some low limit. Adding energy storage (capacitors or inductors) can supply the load current until the next time the rectified AC input voltage is above the desired minimum DC level...
    Look at this simulation: The voltage across the load R1 is plotted as a function of time at various values of filter capacitance... C1 = 1fF, 1uF, 10uF, and 100uF is shown in Green, Red, Blue, and Yellow, respectively. 1fF is very close to zero capacitance...
    Note the current flow in the filter capacitor
  4. Manoj Sahu
    Sep 29, 2014
    8
    What are the factors deciding which filter is to be used in Rectifier circuit.?
    Where pie filter is used in Full wave rectifier circuit or half wave rectifier circuit.?
  5. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,511
    Pi Filter.
    Normally used in a full wave bridge, the decision is often based on whether a very small % of ripple can be tolerated or needed.
    Max.
  6. MikeML
    Oct 2, 2009
    5,451
    1,066
    The ripple has a peak to peak voltage. What is the minimun voltage the ripple can sag to without causing a problem for the downstream circuit(s)? For example, when using a linear regulator, it has a "dropout voltage" where if the input voltage sags below that level, the regulator stops regulating.
    Full wave rectification means that the filter capacitor has to hold up the voltage for half the time compared to halfwave rectification. If low ripple is critical, then use fullwave. If ripple has too much sag with just a simple filter capacitor, then add an expensive inductor. It is usually cheaper to increase the transformer secondary voltage to allow for more sag than to use an inductor (Pi filter).
  7. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,511
    Good Utube demonstration.
    Max.
    atferrari likes this.
