Need "noise free" boost regulator
Discussion in 'The Projects Forum' started by Mikrogut, Jun 10, 2014.
  1. Mikrogut
    Aug 30, 2013
    20
    I need a 5V/500mA boost regulator that can give me 5V from a 3.7V Li-Ion battery. Currently I am using the L6920 together with a 18uH inductor. The problem with the current solution is noise and ripple. I can hear a high frequently squealing from the inductor when the regulator is loaded. In addition there is +/-60mV ripple on the 5V output. I want a small ripple and I don't want to hear the conductor squealing.
    Any suggestions for a 5V/500mA boost regulator that I can use instead?
  2. Sensacell
    Jun 19, 2012
    1,183
    276
    Find one with a higher switching frequency.
    1) You will not hear it
    2) the ripple frequency will be higher and easier to filter.
  3. alfacliff
    Dec 13, 2013
    2,449
    428
    are you using a store bought inductor, or homemade? if homemade, or exposed windings, coat it in epoxy, that will stick the windings down and prevent vibrations. for the ripple, use a ceramic cap to filter out the ripple, using the shortest leads possible.
  4. Alec_t
    Sep 17, 2013
    5,968
    1,135
    If the squeal is due to inductor overload try using a bigger inductor core (higher current rating).
  5. Mikrogut
    Aug 30, 2013
    20
  6. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,686
    1,297
    That is true. Also, Linear Tech has some specialty dc/dc controllers optimized for low noise. But relatively high output noise is a common characteristic of all boost converters. Consider a second inductor as part of an extra output filter stage.
    That's a good group of capacitor values, but as mentioned above capacitor type and placement have as much or more to do with performance than value. Also, pcb layout is critical. Follow the demo board if you can - they usually are optimized to make the part look as good as it can get. In particular, pay attention to any traces near (or under) the inductor.
    ak
  7. ronv
    Nov 12, 2008
    3,393
    1,454
    My 2 cents. I think your inductor is a little small and the current rating a little low. It may be saturating at high current. A little LC circuit or more capacitance at the output should fix the ripple. But for fun sign up for web bench (TI) and look at some of their designs. I just did one below for a couple bucks in parts and 1 mv ripple.
  8. crutschow
    Mar 14, 2008
    13,481
    3,368
    An added LC filter at the output will also reduce (electrical) noise and ripple.
  9. Mikrogut
    Aug 30, 2013
    20
    I only draw about 200mA@5V from this regulator, so I don't think I am overloading the regulator or inductor.
  10. Mikrogut
    Aug 30, 2013
    20
    How about using TPS61230 or TPS61027 from TI? They work at a higher frequency and require smaller inductors. That might help me removing the hearable squealing from my current solution.
    I don't know how the 5V ripple would be, but it can't be much worse than now.
  11. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You don't think or you know for certain? In an SMPS it is not unusual for the inductor current to be much greater than the output current. Thin wire or the wrong kind of core material and the inductors could very easily saturate.
  12. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Agreed. Just use a bigger inductor.
    At a low average current of 200mA it's not going to be critical for DC ohms etc so there is no need to use such a small inductor.
    Larger inductor means less current ripple, and a larger output cap means less voltage ripple per load.
  13. Mikrogut
    Aug 30, 2013
    20
    Today I tried this conductor which I had lying around:
    www.digikey.com/product-detail/en/ELL-6RH100M/PCD1345CT-ND/295721
    The result was that the high frequency squealing disappeared. That was very good! The squealing was probably a result of a saturated inductor. The ripple is still high, but a bigger inductor and a LC filter will probably help.
