Need Motor of 5 to 12VDC to lift the handle Help
Discussion in 'General Electronics Chat' started by mpcotuong, Sep 3, 2010.
  1. mpcotuong
    Aug 26, 2010
    170
    Hi All,
    I am doing project need to lift the handle up for 20second and stop to release the handle. I am thinking the circuit with Motor to lift the handle. Do you know or have any information relate to this project, please let me know.
    Thanks, in advance.
    Kevin
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    "The handle" implies you have some specific handle in mind. We can't help until we know about that handle and about how some motor might be mounted. It might turn out that a solenoid would work better.
  3. mpcotuong
    Aug 26, 2010
    170
    The handle look like door entry handle. I need to lift it by Motor
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That is not informative. Can you say what the mass is and how far it must be lifted? Is there a specific requirement to use a motor?
  5. mpcotuong
    Aug 26, 2010
    170
    That is the information for my project. I need lift it about 3 inches up.
    Can you help?
    Thanks,
    Kevin
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  7. mpcotuong
    Aug 26, 2010
    170
    Yes, it 's similar to that Entry door handle.
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  9. mpcotuong
    Aug 26, 2010
    170
    Thanks, for your help. But I need something to pull it right?
  10. marshallf3
    Jul 26, 2010
    2,358
    201
    You'll obviously need some sort of mechanical interface between the solenoid and the handle and of course some sort of circuit to provide power to the solenoid when you desire it to be activated.
  11. shortbus
    Sep 30, 2009
    4,096
    1,690
  12. Tomax
    Sep 3, 2010
    you can use strong electromagnet for lifting the handle . u can also use timer for the ckt to cut the supply to the electromagnet after 20 sec.
  13. mpcotuong
    Aug 26, 2010
    170
    Do you any circuit to work for motor and merchanical to connect to Motor?
  14. marshallf3
    Jul 26, 2010
    2,358
    201
    Google, scrap metal pieces, hardware and tools.
  15. mpcotuong
    Aug 26, 2010
    170
    Do you have more detail such as diagram about the mechanical ?
  16. marshallf3
    Jul 26, 2010
    2,358
    201
    Can't say that I ever had any need to design, construct, test, debug and then fully document any sort of device like that.
    You're obviously going to have to do some of your own thinking and esperimenting here - every door, latch, solenoid etc is going to be different.
  17. Bernard
    Aug 7, 2008
    4,240
    414
    Use a gear reduced motor to turn a cam which lifts the handle. A switch, SW-1, [should be SW-2 for schematic], closes at maximum lift. Motor only turns counter clockwise. A latching relay controles motor. Handle lift starts when SW-1 is closed momentarly, latching Ry, motor turns untill SW-2 closes- generating a neg. pulse setting 555 high, turning off PNP SW for 20 sec. After 20 sec. motor continues momentarly untill cam drops handle- opening SW-2 which generates a + pulse to NPN T which momentarly shorts Ry causing it to drop out, stopping operation.
