need more help with sound trigger
Discussion in 'The Projects Forum' started by gvi70000, Nov 1, 2009.
  1. gvi70000
    Thread Starter Active Member
    Oct 4, 2009
    34
    hello,
    I need to trigger a camera using the sound made by the splash of a drop of water. The sound is picked up using a electret mic placed at about 20-30 cm from the sound source.
    The best i could think of is posted here http://forum.allaboutcircuits.com/showthread.php?t=29246 but with this design i have to place the mic too close at about 2 cm from the sound source
    I also need to adjust the level at witch the camera is triggered (for popping balloons or water drops).
    Can anyone help me to achieve this?
    PS: I've uploaded two picture with the results I've got so far
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Where are you getting the 1.5V that appears at pin 3 on the opamp?
    hgmjr
  3. gvi70000
    Oct 4, 2009
    34
