Need mini digital multimeter with interface to computer
Discussion in 'General Electronics Chat' started by Venugopalan Govindarajan, Sep 2, 2016.
  1. Venugopalan Govindarajan
    Sep 2, 2016
    I need to a mini digital multimeter which can measure the amp & volt of a line and then transmit the measured values to a computer. How to accomplish this? Is there a device which does that already? The closest i got is this and this.
    Should support around 240V and 80A.
    Thanks.
  2. ErnieM
    Apr 24, 2011
    7,436
    1,625
    Search that site for "multimeter USB" to see some examples of units to make these readings.
    240 v is something any unit will do. 80 amps is not something typically found, so you may need a current shunt to adapt one.
  3. Venugopalan Govindarajan
    Sep 2, 2016
    Did that, but its showing a either large multimeters(12cmx5cm) with usb interface or smaller ones for measuring usb ports in computers(5V range).
