I'm trying to set up a Matlab M file to plot the results from a circuit.
The circuit consists of a source (14.4kVRMS) a line (Z= .75+j20 ohms) and a load(which varies)
I would like to be able to plot the VA across the load, versus the power factor of the load(for both leading and lagging pfs). Now the rub is that I must keep the load voltage within +-10% of the source voltage.
I attached the M-file that I have pulled together so far.
Thanks for your help!
