I think we already did, about as basic as you can get, just change the transformer.guyz I don't want to buy it, whether its cheap or not, and plz post 100 watt inverters
But this inverter doesn't work. It is too simple to work.I think we already did, about as basic as you can get, just change the transformer.
http://www.aaroncake.net/circuits/inverter.asp?showcomments=all
Just an idea, what about using 50hz sinewave oscillator and feeding this to a simple half-bridge PWM? That should generate true sinewave if I am not mistaken.Sine wave output of an inverter isn't possible, unless you create a 100W Linear amplifier having + and - 180V rails, then make the input a sine wave.
Inverting to true sine wave is COMPLEX. That is why it is such a complex circuit diagram.you provided such a complex ckt diagram!
