need info AC current meters
Discussion in 'General Electronics Chat' started by raffter, Nov 25, 2008.
  1. raffter
    Thread Starter Active Member
    Feb 28, 2008
    113
    Hi all,
    WHY do current meters have monitoring on BOTH lines (live,neutral)?? Im talking about current transformers... then both "conditioned" signals are sent to 2 ADC inputs(post processor) ....
    how does it measure current?? getting the average value of the two? etc??
    tia
    -Ralph
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Can you cite a source for that setup? That is usually confined to protective devices like ground fault interrupters, where a difference in hot and neutral implies a current leakage and forces a trip on the breaker.
    In a circuit, the current in the hot lead is the same as the current in the neutral, so measuring one is the same as measuring the other.
  3. raffter
    Feb 28, 2008
    113
    here is one such source:
    http://www.atmel.com/dyn/resources/prod_documents/doc2566.pdf
    now I have made my own CT for this(metal core of course) 1:1000 turns ratio with a 100R burden resistor... I have just made the front end , to make things much simpler.. I can make the PIC/firmware later....
    my problem is this: measuring resistive loads IS OK (like incandescent bulbs and soldering iron<ceramic heater element>) now with reactive loads(like a TV set, I get erronous readings..registering MORE than its actual consumption...
    IS there a trick on HOW to measure with CTs and reactive loads?? or what math equations are involved?
  4. The Electrician
    Oct 9, 2007
    2,301
    339
  5. leftyretro
    Nov 25, 2008
    394
    Yes, reactive loads can skew a measurement that assumes a sine wave RMS type load. There were chips avalible from Analog Devices that would take a low level AC voltage and output a RMS value. It's the same as used on the better DMM that have can read true RMS voltage. So short of adding this kind of input conditioning I can't think of another method for you.
  6. raffter
    Feb 28, 2008
    113
    can RMS value be "CODED" ?? say a PIC to process RMS value??
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Easily, if you can make the conversion at peak voltage. RMS is pretty close to .707 of peak. It's also pretty simple to make the absolute value circuit from the National Semiconductor op amp collection and present the PIC with a voltage also very close to RMS.
  8. raffter
    Feb 28, 2008
    113
    so uhmmm ADC input will suffice as input for RMS conversion??
    regarding NatSemi op-amp collection, what specific circuit should I be looking at?
  9. leftyretro
    Nov 25, 2008
    394
    Not very easily, would take lots of processing resources. The input AC voltage wave shape, (actually representing the AC current being consumed) would have to be sampled many times per single AC cycle and then some calculus performed before you would have the data needed to do an accurate conversion to true RMS power being consumed. External special function IC circuit is much more practical I think.
    PS: Just answered another thread on a similar topic and found this product. Seems it is possible but I suspect they are using a analog devices RMS converter chip.
    http://www.sparkfun.com/commerce/news.php?id=204
  10. leftyretro
    Nov 25, 2008
    394
    That's only true when the AC wave form is a sine wave, which only happens with a pure resistive load. When there is a reactive load the AC current wave shape is no longer a sine wave and the .707 Vs peak rule does not apply. Voltage and current are no longer in phase with each other when there is a reactive load.
    Lefty
  11. The Electrician
    Oct 9, 2007
    2,301
    339
    How do you know that your readings are erroneous? How do you know what the true reading is?
    Are you trying to measure only current, or are you trying to measure power?
  12. raffter
    Feb 28, 2008
    113
    my analog front end "connects" to a Digital VOM(in DC mode) ...output in mV equals watts... my reference "loads" are a ceramic heater element soldering iron(20W) and a 100W incandescent bulb....
    reading of 100mV is 100W...
  13. raffter
    Feb 28, 2008
    113
    Leftie,
    is THAT an LC filter?? :eek: I can see maybe a 0.001R shunt...
    EDIT:
    RC filter.. sorry..
  14. leftyretro
    Nov 25, 2008
    394
    Yea, it's a shunt for sampling the current flow.
  15. raffter
    Feb 28, 2008
    113
    oh I think its NOT an RC filter... more-or-less its an RC line "reducer" :rolleyes:
    to supply power to the circuit... now I get it..
    so "sensing" is purely an ohmic shunt
