Need info about ADC in pic16f877a
Discussion in 'Embedded Systems and Microcontrollers' started by mohamedadly71, Jul 1, 2011.
  1. mohamedadly71
    Nov 18, 2010
    hello everybody
    i am writing a code to read a sine wave of 50hz frequency
    which is shifted by 2.5v and an amplitude 2.5v
    i have to calculate the R.M.S of the wave using 4 sample method
    which i should read a sample from sine wave every 5 milli second
    and by using analoge to digital converter to convert it to digital.
    i want to define the i/p as porta bit0
    but when calculating the value of each sample i found that pic doesn't give the calculated sample on lcd
    so please can anyone teel me if the ADC takes time to convert the sample or explain the ADC briefly
    the code is:
    float t,x5,x6;
    char text2[13];
    int i;
    float y[4]={0,0,0,0};
    void main()
    adcon1=0;
    trisa=1;
    trisb=0;
    lcd_config(&portb,0,2,1,7,6,5,4);
    lcd_cmd(lcd_cursor_off);
    lcd_cmd(lcd_clear);
    for(i=0;i<4;i++)
    x5=adc_read(0);
    x6=(x5*5)/1024;
    y=x6;
    t=y[2];
    floattostr(t,text2);
    lcd_out(1,1,text2);
    delay_us(4900);
    //so by changing the value of y i can read the sample on the screen
    thanks for ur assist
  2. mohamedadly71
    Nov 18, 2010
    i am using an external oscillator of 4 MHz
  3. Markd77
    Sep 7, 2009
    2,803
    594
    What do you see on the LCD?
    I would imagine with the short delay you would, at best, see 1 value.
  4. nigelwright7557
    May 10, 2008
    488
    71
    x6=(x5*5)/1024;
    Are you sure this is right ?
    If you divide by 1024 then the first part needs to be greater than 1024 or you will get a zero result.
