No silly.. thats an octopus hub.. not spider..Here's a prototype using the spider hub recommended by killivolt in #4.
The (O.D. of 3/8" pex is .500) and the (I.D of 5/8" is .574) with a difference of ruffly (.050) that should leave (.025) in the circumference that you maybe can fit the 5/8" tube over the 3/8" ?Here's a prototype using the spider hub recommended by killivolt in #4. The tubing is a little too flexible and makes it a tad wobbly at this size of orb, but I love the hubs. If I had one for 5/8" OD PEX tubing, I'd be done.
View attachment 81040 View attachment 81039
Well it's been a struggle but I have a pretty nice 3D model drawn up. I think it's ready to print but that could be my naiveté. I'm ready for professional help.You draw it, I'll print it.
Since these objects can be printed at 25% fill rate (e.g. honeycomb fill), the density of most of my prints is not high enough for paperweights. You are right though, mostly show-and-tell pieces that end up in the fire wood pile (for outdoor burning).I can supply the STL file if that helps. I don't care about the color of the finished object.
Would it be prudent to test print just 1/8th of the model - one of the "arms" - to verify that PEX tubing fits into the hole? I'd hate to make an expensive paper weight, although that seems to be the main use for 3D printers.
Well, I'm the designer, so I can speak for ... me....you might want to ask the octopus designer if they want all PEX pipe in the same plane exiting the core. It would look a little more 'organic' if it had some variation to it.
I had no idea. That doesn't seem to be an option at the online print shops but maybe I missed it.Since these objects can be printed at 25% fill rate (e.g. honeycomb fill)...
I am getting projects confused... a bit. In your first post, you said you were doing this for a friend. I assumed it was an octopus project. Now I remember the octopus was for my wife's friend (her daughter is an octopus in a school play and needed a costume. Another story associated with 8 ). Anyhow, you said "All in the same plane" and you have what you need.Well, I'm the designer, so I can speak for ... me.
I'm not sure I follow your comments. My goal is something like the hub in #25, so that two can be used to make an orb. I have considered tilting the arms just a hair towards the central axis, towards the center of the sphere, to give a more rounded look, but I think that's an unnecessary trifle compared to the flexing of the PEX.
You could also make the 5/8" inlet larger and add a nut-cage to your design. Slide a nut for a #8 screw into the cage and tighten the screw through the nut (held from turning by the cage) and the screw goes into the PEX to either wedge it into place (if you leave a rib on the far side of the screw for the PEX to deform against) or you could drill a hole into the PEX to accept the screw. In this case, the tightest tolerance you need is to prevent the nut from turning in the cage. My son designs the cages into everything he makes because they are so easy to make in 3-D printing. The only work is the design and he claims that is easier than holding a wrench on the nut when he assembles something.The PEX is 5/8" OD with an ID just under 1/2". The 5/8" OD is the controlled dimension, they let the ID vary more than the OD.
The "quality check" I would perform on the prototype hub is to verify that the PEX tubing goes into the arms and that the part seems solid enough to hold an orb together. I could rely on someone else's eyes to assess both issues as long as they have actual PEX tubing to test with.
I might need as many as 6 or so of these - three pairs with one pair for each orb - but that's a rough guess. If you need a better answer I can press my friend. The answer may depend partly on the cost per unit.
I'm sorry, what I've been calling 5/8" is actually know as 1/2" PEX. It's actual OD is 5/8". The industry's nominal 5/8" is indeed 3/4" OD, but that is not what I'm using.Wayne,
What size PEX again.. (whats the OD).. I think 5/8's is 3/4" OD
by Don Wilcher
by Jeff Child
by Aaron Carman
by Jake Hertz
