Helping a friend with a craft project. It involves bringing 8 pieces of PEX tubing together into a hub, all in the same plane and equally spaced at 45°. I need ideas how to connect 8 ends of PEX together.
I made a prototype from a piece of oak by cutting it into an octagon and then drilling a hole in each face. The hole diameter matches the 5/8" OD of the PEX.
This prototype works well but I'm looking for something:
1) easier to make - she needs at least 10 hubs, and that would be a lot of miter cuts and 80 drilled holes, ie. a pain
2) more stable against the elements - this is for an outdoor display, the oak may be OK if I treat it with anti-rot, which I have
3) more elegant - the wooden block still looks...blocky.
I'd prefer an 8 pointed star that I could slip the PEX over, instead of a block to slip the PEX into. The ID of the PEX is between 7/16" and 1/2". I think you could heat the PEX and slide it onto 1/2" with some effort.
They sell hose-barbed tubing fittings in a cross, and I've considered mounting 2 together at 45° to each other to get 8 ends together. They wouldn't be in the same plane but it might be close enough. Trouble is, these things aren't cheap and they're not locally available.
I've thought of using pieces of threaded rod welded to a flat washer, but I have no welding tools or experience.
Thinking caps on?
Thinking caps on?
