Need Idea for Project
Discussion in 'General Electronics Chat' started by MIRINGU, Oct 19, 2007.
  1. MIRINGU
    Thread Starter Active Member
    Mar 18, 2007
    75
    The project is a digital thermometer. pls help mi with a simple circuit schematic
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    "Hijacking" of a thread is considered rude. I have moved this inquiry into it's own thread.
    What kind of project are you interested in? We respond better to specific questions than to general ones. We will not do your work for you. But once we see which direction your work is going, we will gladly help if we can.
  3. cumesoftware
    Apr 27, 2007
    1,330
    11
    You have to have some ideas of what you want to do, no? Tell us what is your knowlegde level of electronics, so we can propose a suitable idea to you.
    In the line of thingmaker's thought, and as I said several times, we don't make POD (projects on demand here). If we made the project for you, we were not helping you at all. It is you that has to build the project. We are here to give you support. That way you will not only apply what you've learned, but also learn a bit more more about electronics.
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    This is far to broad a question to be of any use, you really need to narrow the question down a little. Define "electronics principles".
    Dave
