Need idea for NFC project
Discussion in 'Wireless & RF Design' started by dudeism, Jul 18, 2016.
  1. dudeism
    Jul 13, 2016
    13
    I have to use my phone's NFC to turn ON another circuit or another system like zigbee or bluetooth. So far I have only shown how an LED glows using my phone's NFC. I used copper wire turns and connected an LED to it on a breadboard. What should I do next?
  2. DickCappels
    Aug 21, 2008
    2,773
    669
    What do you want to accomplish?
  3. dudeism
    Jul 13, 2016
    13
    My project is to design an NFC transceiver system for contactless applications. However, it is not too specific. I can use NFC along with other systems like bluetooth . I have to analyze data rates and power consumption at different distances.
  4. dudeism
    Jul 13, 2016
    13
    how much current and power is required for NFC tags?
  5. DickCappels
    Aug 21, 2008
    2,773
    669
  6. dudeism
    Jul 13, 2016
    13
    Can you suggest some NFC circuits for transmitter and receiver?
  7. DickCappels
    Aug 21, 2008
    2,773
    669
  8. dudeism
    Jul 13, 2016
    13
    Can you help me.In the first one which NAND gates he uses in transmitter schematic?
    I got it. Thanks.
  9. dudeism
    Jul 13, 2016
    13
    I am making the circuit in multisim. Can you help me? Which crystal oscillator should I use?
  10. atferrari
    Jan 6, 2004
    2,666
    784
    DickCappels likes this.
  11. DickCappels
    Aug 21, 2008
    2,773
    669
    The choice of a NAND gate is yours
  12. dudeism
    Jul 13, 2016
    13
    Can anyone suggest an amplifier circuit for 13-15 MHz frequency?
  13. BobaMosfet
    Jul 1, 2009
    110
    11
    Isn't this thread a violation of TOS? In particular the 'transformerless power supply' clause. The OP stated they are attempting to power an LED using energy from an inductor only on their breadboard.
    I was informed that there is no 'grey area' or 'leniency' on this subject . If the TOS stated 'Non-MAINS-isolated power supply' instead, there would be no issue.
  14. dudeism
    Jul 13, 2016
    13
    For the circuit, can the transmitter work without a micro controller?
  15. DickCappels
    Aug 21, 2008
    2,773
    669
    @BobaMosfet I am glad you read the TOS and are paying attention. Since it is not connected to the mains it is not in violation of the TOS.
    Yes, the output of the LM358 in the receiver circuit attached to post #14 (which is the output of the LM318)) can be used for data to as an on/off signal, such as blinking an LED or driving a relay, though to drive a relay you would require a transistor.
