1. hamran
    Aug 21, 2006
    10
    i have a graduation project titled implementation,simulation, and synthesizing of PID controller in vhdl. i 'd like first to model the pid controller and then write the vhdl code , can any one help me with that as it is analogue system........????????????
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    You should have access to IEEE Explore: http://ieeexplore.ieee.org/xpl/freeabs_all.jsp?arnumber=4153154
    As the paper says, "The main problem of this approach is the difficulty to tune the VHDL code into the final electrical system. That is why the article also describes the simulation framework needed to validate the model using simulink. "
    If you want further help, you will need to be more specific with your query.
    Dave
  3. hamran
    Aug 21, 2006
    10
    thanks dave for that but i really need help in using VHDL-AMS and differences it makes from VHDL, and what software can help me in writing that code ( behavioral and structural)
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Although I have heard of it before, VHDL-AMS is new to me since I have never had the need to use it. There is a book called "Modeling and Simulation for RF System Design" which through a treatise of the introductory concepts of VHDL-AMS covers development of PID controllers. Check ISBN: 978-0-387-27584-0 or DOI: 10.1007/0-387-27585-1_6
    There is also one covered here: http://ieeexplore.ieee.org/Xplore/login.jsp?url=/iel3/4067/12057/00555297.pdf?arnumber=555297
    If you have access to MATLAB I would also suggest you have a play about with: http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=4799&objectType=file
    I cannot be much more of help than that.
    Dave
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
