need help
Discussion in 'The Projects Forum' started by oolesh, Apr 26, 2012.
  1. oolesh
    Apr 21, 2012
    24
    $(KGrHqV,!jcE8FTVvZT3BPLG0QVpdg~~60_12.jpg hi everybody i need a SSR for some project!! i have a question the SSR input is 3-32vdc it's fine but the output is 24-380vac 25A so can i put 12vdc
  2. #12
    Nov 30, 2010
    16,665
    7,310
    First guess, without you telling which SSR you are using: NO
  3. oolesh
    Apr 21, 2012
    24
    the model is 'SSR-25 DA'
  4. #12
    Nov 30, 2010
    16,665
    7,310
    Final answer: No
    This device uses a triac for its output. It will not turn off if you get it started.
    If it has a zero crossing detector on the input, you will never get it started.
    oolesh likes this.
  5. oolesh
    Apr 21, 2012
    24
    ok but last question do u think if i can get a SSR that the minimum input is 3vdc and the minimum output is12vdc?sorry for my bad english
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    They make DC SSRs, but that is not one.
    oolesh likes this.
