Need Help.....
Discussion in 'Homework Help' started by rrrr4950, Jan 3, 2012.
  1. rrrr4950
    Dec 23, 2011
    5
    Can someone tell me which best describe Frequency.
    1.Cycle per second
    2.Hertz
    3. Cycle per second
    Thank you for your help greatly appreciated....
  2. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    could #1 be best, but #3 the worst? You have some confusion over the concept and its units. Frequency is better described as cycles per unit time. If the time is a second, it is cps or another word ( better in many cases ) Hz. Google could tell you all this and more.
  3. t06afre
    May 11, 2009
    5,939
    1,222
  4. Adjuster
    Dec 26, 2010
    2,147
    300
    Your first and third options seem to differ in their font size - have you made a typing error? Leaving that aside, the answer will depend on what is meant by "describe".
    The SI unit of frequency is the Hertz, which can be described as a cycle per second.
    In the past, the unit of frequency was actually the cycle per second, but this officially became the Hertz in 1960.
    If this is the answer to some multiple-choice paper, you may be reduced to guessing.
    http://en.wikipedia.org/wiki/Hertz http://en.wikipedia.org/wiki/Cycle_per_second
