need help
Discussion in 'General Electronics Chat' started by juv, Dec 27, 2011.
  1. juv
    Dec 27, 2011
    i need to trigger a thyristor using a micro...and iam looking for the circuit and the program of it??:)
  2. R!f@@
    Apr 2, 2009
    8,785
    771
    Welcome
    And good luck with what ever u r looking for ?
  3. Bernard
    Aug 7, 2008
    4,231
    414
    Use opto coupler with triac output, something like a TLP3042, " 0" crossing; PN A10035, Electronic Goldmine.
  4. Adjuster
    Dec 26, 2010
    2,147
    300
    Please give more detail. Many people might think micro = microcontroller, and your reference to a program supports this, but depending on your language background you might as easily be talking about a microphone.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Here is the datasheet for the TPL3042 that Bernard mentioned:
    http://www.toshiba.com/taec/components2/Datasheet_Sync/210/11298.pdf
    You might also consider the MOC3052; Mouser stocks them:
    http://www.mouser.com/ProductDetail...=sGAEpiMZZMteimceiIVCB7OZToIkTRfkfUoveAoqsbw=
    $0.85 USD each, no minimum purchase.
    Datasheet:
    http://www.fairchildsemi.com/ds/MO/MOC3052M.pdf
    There are also these:
    PR39MF51
    http://parts.digikey.com/1/parts/757290-relay-ssr-240v-0-9a-8-dip-pr39mf51nszf.html
    $1.38/ea, non zero crossing type, 0.9A 600V
